Hello Support team,
what’s the max number of rtmp sessions to stream to different CDN?
BR
MTamer
Hello Support team,
BR
MTamer
That would be entirely dependent on your network upload bandwidth, as well as the encoding settings used for the program channel, and whether or not you are using network-based video sources with Pearl. Pearl uses a gigabit connection over Ethernet.
As an example, if you have a 6Mbps encoded bitrate, no network video sources, no local unicast stream connections in use, and accounting for overhead/fluctuation (assuming you have a guaranteed 1Gbps upload speed for your internet) you could likely doing up to 6 simultaneous RTMPS streams (depending on the complexity of your Pearl configuration) - possibly 7, but that’s very dependent on the setup.
