Can anyone tell me if a Cannon xa45 will play nice with webcasterx2. I’m in a bind and need a camera quick… I’ve tried the list but, evidently it’s not kept up to date… Anyone ??
Are you planning on multi-camera stream? If so, look at the Blackmagic ATEM Mini. If you have cameras with different video standards, this switch can re-sync them so the feed will show up on the Webcaster X2.
Does it convert the signal required for webcasterx2 ?? Any camera?
No just need this camera to work with webcasterx2.
Blackmagic ATEM Mini makes it possible for me to re-use my existing cameras (1080i) to use with Webcaster x2.
Look halfway down, automatically convert HDMI input formats.
https://www.blackmagicdesign.com/products/atemmini
Well I m going to buy one… Right now hope it works…
Thanks for your time… I do mean that.
Have a great night.
