Video splitted in two parts and something is missing
I recorded a talk some weeks ago and my Pearl 2 cuts the Video after 27 minutes and resumed it automatically, unluckily some seconds are missing. The maximum filesize is 64gb with unlimited time. So I have no clue why Pearl stops.
Is that a known issue with that device or shall I change my settings?
Greetings
I would recommend to verify your channel “encoding” settings. If you have multiple video sources, where the frame size differs, and are doing a live switch between those sources with the option “use current signal resolution as frame size” Pearl is forced to stop, detect the new video source, adapt the frame size and then resume recording. This would cause a break between two recordings.
If you uncheck the option and select a static frame size, Pearl ignores the signal source frame sizes and continues recording or streaming without issue.
