Hoping to find a solution or way to get my vga plus audio signal into my av.io.
I have an older set of Extron vga over Cat5e boxes that have separate vga and audio inputs at one end, and separate vga and audio outputs at the other end.
I can connect my vga to dvi cable that came with my AV.IO and get the video signal just fine, but I want to get the audio thru the DVI cable as well.
Does Epiphan sell a vga with audio in to dvi out converter or cable?
If not, does anyone know if a cable such as this exists?
NOTE: I read the primer regarding how Epiphan is getting audio over the DVI input.
Thank you in advance.
Wally
