Hello
I noticed that the DVI2USB 3.0 also works with a USB 2.0 cable. The user guide states that the video transfer frame rate is reduced when using USB 2.0.
What frame rates can be expected when using USB 2.0? Does this depend on the input video resolution? Are there limitations concerning resolution when using USB 2.0?
Thank you for your input
(edit: I read that embedded audio is not supported with USB 2.0. That’s fine.)
