Upgraded from VGA2USB to AV.IO HD
So at work we finally upgraded from VGA2USB and now have AV.IO HD.
The downside is the Epiphan Capture Tool software wont work with the new AV.IO HD which is very unfortunate. So before I go off in the deep looking for something to work I figured I might as well ask and see what other people are using.
What I was doing is using the Epiphan Capture Tool software and Camtasia to capture the other computers screen displayed in the Epiphan Capture Tool.
So, any suggestions on what software to use like I was using the Epiphan Capture Tool?
Thank you in advance for any helpful answers.
There are a number of applications you can use. If you are running Windows 10 then the easiest option would be the Windows Camera application. Alternatively, as it sounds like all you need here is to view the signal, VLC media player would be an easy option too!
Windows Camera: https://www.microsoft.com/en-ca/p/windows-camera/9wzdncrfjbbg?activetab=pivot:overviewtab
VLC: https://www.videolan.org/vlc/download-windows.html
