Hello!
We own a pearl nano and have tested several times to stream on twitch. It always works the first time but when I try and do it a second time with the same stream key The blue stream light just blinks. To make it work again I have to reset my stream key on twitch, This isn’t something that I should have to do every time as the same stream key should work every time.
Am I doing something wrong?
Hi ECU_SOTD,
After digging into this a little further, Twitch did release a statement that after their hack/breach, for safety reasons they have reset all stream key credentials for accounts. For the moment it appears that they are leaving it as single-use stream keys which require a reset after each streaming event, but this may change back to a permanent stream key option in the near future
" “Out of an abundance of caution, we have reset all stream keys,” Twitch said on its blog. “Depending on which broadcast software(or hardware) you use, you may need to manually update your software with a new key to start each stream.”
