Hello I am planning to buy the Epiphan adapter to sync HDMI video from my camera and USB audio from YAMAHA AG03 that provides phantom power to my condenser mic.
Will it be possible? If yes, which software will be able to do that? YAMAHA ag03 comes with Cubase.
This was posted in our Pearl Mini forum. Are you looking at using the Pearl Mini here? You can see more information on the Pearl Mini here: https://www.epiphan.com/products/pearl-mini/
Or are you instead looking at a USB capture device and just posted in the wrong forum? Please let me know and I would be happy to help.
Yes, sorry it is the wrong forum, I was thinking about a USB adapter
Ah I see, in that case you could certainly capture the HDMI from your camera into your computer via USB 3 with something like our AV.io HD: https://www.epiphan.com/products/avio-hd/ But they are indeed likely to be out of sync as they came in via very different routes. Ideally if you could input the audio into the camera this would be ideal as it would then maintain sync. But otherwise you will need to look at making sync adjustments in the software you will be using on the computer. Most streaming software does have adjustments options here though.
