I can stream to FB OK. However when I schedule a livestream for the future it does not start automatically. My guess is that when I am scheduling the live stream a popup shows information on a stream key which X2 does not use, and FB will not let me choose the paired option. The post is created and counts down to the start time but just stops 0 minutes. I think that since I can not tell it my device code it does not know which stream to start. Can you please post step by step instructions?
Unfortunately Webcaster X2 does not currently have any scheduling features. If you select a scheduled event within the “Publish Destination” field under preferences, you will still need to manually start/stop the Webcaster X2 stream from either a mouse click in the user interface or from the multi-function button on the side of the device.
