Is it possible to use the two XLR/TRS and the two RCA Audio Inputs simultaneously? In other words, is there a possibility to mix the four above mentionde audio channels to a one mono channel. Farthermore, is it possible to mix the XLR/TRS and/or RCA Audio input with the audio input coming over HDMI?
Thank you very much in advance for an answer.
Best Regards,
Robert
Hi Robert!
The short answer is yes, on the Pearl Mini you’re able to use the two XLR/TRS and RCA audio inputs simultaneously. Using the admin panel you can select any audio source you want (including embedded audio over HDMI) and combine it with any other source. In the encoding settings for a given channel you’re then able to select stereo or mono.
The only caveat is that you don’t have total control over each channel (Left or Right) of the RCA input, so if you select mono in the encoding settings it will equally mix down the RCA stereo channels into one mono.
Thank You very much Adam for the fast and helpful Answer!
Best regards,
Robert
