I don’t know if this is possible (it may be hardwired) but for my use case it would be nice to allow the confidence monitor screen on the Pearl Nano to be switched off while leaving the audio from the 3.5mm audio socket active.
Currently they are both tied (can’t have one without the other).
This is a great question! Unfortunately, it is not possible to disable this functionality. We built this into Pearl devices as a security feature - if the display is turned off, this commonly means an administrator doesn’t want anyone interacting with the physical device, so we disable the headphone jack as well.
Once the screen is turned back on, audio should once again be heard from the headphone jack.
