I have DVI2USB 3.0 and DVI2PCIe frame grabbers and I’m trying to setup them with my device.
I have an embedded device which generated LVDS video output.
setup is following:
device -> display
-> LVDS to DVI -> frame grabber
when using the device with its display - everything is fine - video is always displayed.
but when I connect the frame grabber - I do not get a signal in the epiphan tool.
Usually, It just say “No signal detected”
if I unplug-plug couple of times the DVI connected/USB, it’s gets “synched” and I see the video signal also in the epiphan tool.
What could be the problem?
same setup is tried with both DVI2USB and DVI2PCIe (latest drivers) - I always get the same result.
at first - no signal. after couple of unplug-plug - the signal comes
Unfortunately our grabbers are not compatible with LVDS/Spread Spectrum signals. Interesting that you are able to make the signal come through after some unplug/replug cycles. Unfortunately we would not be able to provide any support for this use-case.
My apologies for this inconvenience. If you have further questions you can email us at info@epiphan.com and we will open a support ticket.
What is the make and model of the LVDS to DVI adapter? I believe it would need to be an active adapter to change the signal enough to make it fully compatible.
Hmmm okay, thank you for that. I took a look at the specs and documentation and it does seem like the board should work, unfortunately we have never tested this board specifically to my knowledge.
A couple things I would check:
What is the resolution and refresh rate of the output of the board when used in conjunction with the LVDS source? I’m wondering if perhaps there is a resolution and/or refresh rate mismatch occurring here. I can see in the specs of the board that it can go up to 165mhz and that’s not something our grabbers would support I don’t think.
1920 x 568 x 60Hz
I was also thinking of the same… I was feeling that there is something wrong/corrupted with the video signals … but if I hook it up to its original display - it’s always shown perfectly…
That’s an odd resolution but it’s still within spec so it should work. Just to clarify, you mentioned that after you unplug and replug the source a number of times the signal does actually come through? Does it come through at the expected resolution and does it remain stable after?
