Hi, i have a TMobile T9 mobile hotspot and am unable to connect to it with the Webcaster. It seems to briefly connect and then drop. I checked the speed and everything seems good. Is there a setting I need to adjust on either the hotspot or webcaster to make it work? If anyone has any ideas, let me know.
Webcaster X2 would simply connect using Wifi or Ethernet to a network - whether that is an established network or hotspot. The settings would be adjusted from the Settings > Network section of the Webcaster interface
