NDI input quick question
Will NDI input be supported on Mini ? Is it even possible or hardware limitation ?
Regards,
Currently there isn’t a plan to support NDI input on a Pearl Mini. This is indeed a hardware limitation as NDI input would be fairly costly to CPU resources.
Thank you fot the quick answer.
