Is there a way to access the CPU temp perhaps through API or HTTP? That way I can look at it without havint open up the interface and scroll through the info.
Hello! Indeed
Please use:
Pearl_IP/api/system/status
Result will look something like this:
“status”:“ok”,“result”:{“date”:“2023-08-04T16:37:14-04:00”,“uptime”:792441,“cpuload”:16,“cpuload_high”:false,“cputemp”:60}}
Thanks! This was super helpful.
But I’m having trouble implementing it into my own javascript. I’m getting CORS restriction errors. I also posted in another thread specifically for that. But that’s the same hurdle I’m coming into for a lot of things.
I’m glad it was helpful
Interesting - I don’t believe the REST API should cause CORS issues.
Can you please email support@epiphan.com and provide an example of how your entering the API commands and the response?
