instead of using a monitor with hdmi IN can you use an ipad as a monitor for the wcx2?
A monitor would need to be connected to the HDMI OUT of Webcaster X2. HDMI IN would be for the video source you wish to capture for streaming.
Unfortunately an iPad is not a monitor or display and does not have a video input natively so it is not possible for a direct connection. You would need to connect HDMI out to a capture device that would then be connected to the iPad, and you would need to open capture software on the iPad in order to view the content from the Webcaster X2. There would also be added latency between the live source and what you are seeing on the iPad.
