Thank you . I really appreciate any help!
I am working on a webcasting kit proposal for a non-profit. I may be missing some logic. Why would I use x2 for streaming rather than my macbook?
Audio mixer is something like
https://www.behringer.com//Categories/Behringer/Mixers/Analog/Q802USB/p/P0ALM
Will use Video inverter if needed.
Video switcher is something like
Roland Pro A/V - V-02HD | Multi-Format Video Mixer**
Using either a Webcaster X2 or streaming software on your macbook are both great options! The nice thing about the Webcaster is that the macbook wouldn’t be used at all. But if you would prefer to use streaming software on a macbook this would work perfectly well, you would just instead need a capture device to bring in the HDMI signal, for example our AV.io HD would work well here: https://www.epiphan.com/products/avio-hd/
Thanks. Reading about the AV.io
