Hi there,
i frequently see this error when adding a SRT stream as an input (Haivision Hub and other sources)
Disabling hw acceleration does the job.
any advice on this?
Hi there,
any advice on this?
Different hardware options may affect compatibility differently. This is not something we have commonly seen and would require a deeper dive into your setup to troubleshoot and investigate. I’d recommend sending us an email at info@epiphan.com with:
*Permanent logs can be found on the maintenance page of the Web UI, near the top. If permanent logs were not previously enabled, please enable the logs and recreate the SRT source integration so that they can be added to the logs for investigation
Informations sent, thx.
