Hi - does Epiphan make an external SD card reader for Pearl mini formatted cards? I often record multiple meeting room sessions simultaneously at conferences and it would be so much easier if I could swap out the SD Cards between sessions to dump the recordings (often three channels per deck) in a central location. If Epiphan doesn’t make one do you know of one that will read your format?
Unfortunately we do not make or offer an external SD card reader. The SD card formatting on the Pearl Mini are EXT format, which would be compatible with Linux, however would not be compatible to read on a Windows or Mac system.
