Installed a new pearl 2 with latest firmware. In Live i can not select the switcher. It is grey.
I need this to switch between sources
Patrick
Patrick
In order to allow for switching, you will need to ensure that you have additional layouts configured within a channel. The switcher allows you to select from channels with pre-configured layouts. Once the channel has been selected it will allow you to switch between those layouts in that channel.
