Hi everyone!
What is the ideal environmental temperature range for a pearl-2?
Will it work in a small room where the temperature can get up to 24° C?
With kind regards
Christian
Hi everyone!
With kind regards
Christian
Hello!
All Pearl devices should be fine in this environment
Please see our tech specs for environment min/max:
Pearl-2 has a closed loop fan control meaning the fan speed will increase as the system gets warmer, but you can also set the fans to spin at full speed if you notice the room to be a little warm.
The more important variable is that the Pearl-2 airflow is not impeded and the most crucial thing is ensuring the bottom front intake or back exhaust vents are not blocked or have warm air from other devices recycling through them.
