Is there is a possiblity to use the HDMI output (really a DP ->HDMI) into the webcaster X2 ?
I would like to use USB camera and the PIP function with the content of HDMI computer.
It should work if the Surface Pro is detecting the Webcaster as a 2nd display. You may need to try and manually enable it.
But generally speaking, HDMI from a computer into Webcater is not a problem at all.
I have tested a Miracast adapter previously, and unfortunately found the output to be HDCP encrypted. Assuming this is the case for all Miracast adapters this would mean they are not possible to be captured from unfortunately.
