Channels and layouts
My church just purchased a Pearl Mini. I brought it home to get familiar with it. I created channels and layouts. When I move it back to the church and it is on a different IP address will I be able to access the channels and layouts I created on my home IP address from Admin?
Yes indeed! A configuration created on Pearl stays with the unit, unless if you factory reset the unit or change to a different configuration. Everything is stored on the unit itself. The Web UI from a computer is simply the means of accessing the Pearl Mini directly!
I moved to the church but now I have a fresh screen. None of the layouts, streaming or encoding information is there.
Settings should stay unless if the “Save” button was not pressed during configuration, or you accidentally factory reset or loaded a different configuration preset. for support please email info@epiphan.com
