I’m in YouTube hell - the account was last used with Wirecast, and I can’t change the settings back to let my X2 run the show. I get an error on the X2 screen that says user not allowing stream. Please help!
I would recommend you check: https://www.youtube.com/features and make sure that Live streaming shows Enabled here. If it doesn’t then click the button to Enable live streaming, this will just take 24 hours to apply.
I can stream to 6 different you tube accounts (I tried hem all), but not the one I need for tomorrow. THe account was last used with Wirecast, and I was able to blow out the profiles, but somehow it’s not letting me get past this error. I’ve restarted, repaired, and nothing changes.
This is the first problem I’ve had, and I’m convinced it’s not my hardware set up it’s YouTube.
Just don’t know what to change.
Can you please check this page: https://www.youtube.com/features Making sure you have the correct account currently in the top right corner.
Then make sure that the account is verified, that there are no copyright or guideline strikes, and that live streaming here shows as being enabled.
