Hello everyone, I’m fairly new to this so Forgive me. This morning as I powered on the Webcaster X2 it started to cause static on our wireless mic receiver. Changing the channels on the mic receiver didn’t solve the problem. Is there anything in the Webcaster settings to fix my problem? Connecting to LAN isn’t possible with my current location (Router is in basement and Webcaster X2 is in a 100 year old church sanctuary on other end of building). Any suggestions on how to stop the static besides plugging into LAN? Thanks
Unfortunately there are no settings in Webcaster X2 that can be changed however, Electrical interference or static is more commonly caused by electricity. Try utilizing on different power plugs or a better grounded power bar. This may help with your issue.
I Will try it. Thanks
What kind of wireless mic? I had noise issues with an old Azden and switched to Polsen ULWS-16.
