We are having a wierd problem with the pitch of streamed audio going to YouTube. I haven’t added this thread to the YouTube section as I suspect it would be the same with any streaming destination (though we only use YouTube). We get a warning to say the audio sample rate is a little off the expected at 44800Hz but another thread suggest this warning can be ignored. There is also a thread about audio being off pitch but it’s not the same issue as we are seeing.
The audio reaching the X2 is fine and the pitch is correct (I have proved this) but in the YouTube stream it is significantly pitched up. The stream audio is only ever talking and there is a definite tendency towards the chipmunk the audio that reaches YouTube.
No idea what is going wrong here but my suspicion lies somewhat in the difference between the expected sample rates and the actual sample rate. Would the X2 for instance accept the audio at 44800 but stream it at one of the expected sample rates of 44100 or 48000 in the process causing a pitch shift?
Any suggestions on how to resolve are welcome.
