After upgrading to the latest firmware, 4.5.1e, The audio monitoring bar that was overlayed on the video disappeared. Is there a selection box to re-apply it? If not why was it removed. I found it a useful feature.
The audio meter should always be present on Pearl-2, unless if no audio source is selected in the channel or layout. If audio is in fact selected in the channel and layouts, it could be a configuration issue that may require a factory reset to correct.
The bar was not there after the firmware application and reboot. Between posting and now, I rebooted again through the interface and it re-appeared. I am sure it was not showing up before the second reboot. Audio and video was streaming but having odd dropouts. I have not had this issue with previous firmware upgrades. Cheers.
It’s possible it could have been an odd glitch with Browser caching as well. If the issue appears again try clearing cache and cookies. That may do the trick
