looking for a solution to stream just AUDIO with the PEARL2
Single channel audio
If a single channel is all that is needed, then a single Instreamer can be used:
• Configured to multicast to the Audio Signage App’s default channel:
• Input Source: Line Mono
• Audio Format: PCM / 24kHz 16bit mono little endian
• Streaming Mode: send always
• Streaming Destination:
• Connection Type: RTP
• IP Address: 224.9.9.99
• Port: 4444
• Connected to the audio source
https://www.barix.com/fileadmin/data/Manuals/Audio_Signage_Solution__1_.pdf
