I did a Facebook Live stream and the audio was 8 frames ahead of the video @ 30 fps. Any ideas on how I can fix that? Thanks.
- Gary
If the audio and video arrive at the Webcaster X2 in sync then this should be maintained, unless you run into a bandwidth issue which can cause Facebook to lose proper sync.
Can you connect a monitor to the HDMI output of the Webcaster X2 to test and see if the audio/video here are properly in sync?
I have a question does only happen on Facebook or
Youtube also?
