Historically, all Canon DSLR cameras output an interlaced signal and do not output live audio over HDMI.
You would be able to use it with third party adapters such as a signal converter (ex: Sewell Echo V2) and an HDMI audio inserter or a UAC standard 3.5mm to USB adapter
But canon eos r is not DSLR camera, it’s mirorless. I saw in specifications that it has audio output and 1080p 59.94 through HDMI. Is that enough to use it with Epiphan Webcaster x2?
Theoretically yes, however we have never tested the camera specifically. The EOS/Rebel series lines have always listed options for 1080P or 720P Recording modes, but the outputs have been historically been interlaced, and the audio output over HDMI has been playback only. You could test the audio by connecting it to a television to see if you get audio with a live signal.
From what I am reading online the A5100 does have a clean output and can output HDMI in 1080p. This should work well, though I haven’t tried it myself.
Thank you for your time in looking into this. We are wanting to use to Livestream Church services while in a hotel and later in outside events linked to our phone. Blessings
Sony HXR-NX5U works fine. Set HDMI output to 720P.
Cerevo Livewedge video switcher works fine. All input sources should be 720P or 1080P.
Connect to Webcaster X2 from HDMI output on switcher. You can control camcorder output volume with livewedge app on an Ipad conneted via wifi to the switcher.
My experience with the FDR AX53 is that it will output to the Webcaster once its set to 4k. Problem is that it wont record internally also as a backup.
any one here have good suggestions for webcams? I have been using a usb grabber for powerpoint but I’m wanting to get a cheap “second camera angle” thing going instead
